What are the guidelines to be followed in Rf design?
suga.v
Newbie level 2
Newbie level 2
What are the guidelines to be followed in Rf design? Can anybody send the documents & Guidelines reg. RF Design.
Thanks in advance.
Regards
Suga
Re: Rf Design
I think razavi book for rf microelectronics is a good start
Rf Design
Thanks for the reply.
But In net where could I find the guidelines? Is there any website specifically for RF design? If so Plz tell me the website.
Thanks once again.
Regards,
Suga.
Re: Rf Design
Thanks once again.
Regards,
Suga.
just try the search tool on this BBS,you may get it here if you are lucky enoguh.
Re: Rf Design
The best practise in Rf design is to keep the signal trace length as short as possible, provide a proper return path for all RF signals using power/gnd planes. If the circuit is more radiating then you need to provide shielding.
Some more points...
# avoid sharp corners.
# keep signal traces and component leads as short as possible.
# inputs and outputs should be far apart, so that RF energy will not leak back from output to input. stages should line up, rather than snake around.
# decouple the RF parts of the circuit from the DC parts of the circuit.
# shield AF and IF components from RF components.
Nagaraj.
Reactions: avmdi
    avmdi
Re: Rf Design
U told to avoid the sharp corners.
What is the advantage for using the smooth corner traces?
Pls explain me more..I'm new for Rf layout design
Reactions: avmdi
    avmdi
Rf Design
find RF microelectronics here:
Re: Rf Design
Nagaraj.
also avoid splitting those planes under high speed signals
if it necessary use stitching capacitors i.e: capacitor linking the two splitted planes under the signal
Mahmoud
