What are the differences between rs232 and rs432?
buts101
Full Member level 3
Full Member level 3
rs232 and rs432 what are the differences...???
rs 432
the difference being RS432 uses 5V signal levels wheras RS232 uses 12V
rs-432
rs232 has some limitations: speed 15 m. extension cable, ... EIA produced RS449 to avoid this limitations. RS449 is composed of two stardards: rs423a for asimetric transmission or not balanced and RS422a which used in balanced transmission.
Some caracteristics of rs423:
- 60 metres maximun between two terminas.
- 2Mbps in rs422 or 40Kbps in rs432.
- 37 pins connector and 9 pins connector if a second channel is used
Hope this help.
(Sorry for my english).
what is rs 432
speed,distance and most important cost.
