What are the differences between AT89S5x and AT89C5x?
Navid T
Full Member level 3
Full Member level 3
Iran
about atmega
hello
what differents are between AT89S5x and AT89C5x? only speed?
thank you
Re: about atmega
Hi Navid,
atmega is a trademark of Atmel AVR. I don't know why did you call the subject this way, when you're asking about AT89 series.
When you'll want to update the program, AT89C5X must be removed from the PCB, programmed on external programmer and then fitted back.
AT89S5X could be programmed either fitted on the PCB (no need to remove it) or on external programmer like AT89C5X.
That's the main difference.
Add to the above that AT89C5X will be discontinued by the manufacturer (no date limit until now).
Re: about atmega
why not download both datasheets and compare so that you could get more information
Re: about atmega
ATmega are AVRs, it's completely different from AT89s5x or AT89c5x, although most are pin compatible.
AT89s5x are newer than AT89c5x, with some advantages:
1. price almost the same
2. ISP programming (in-system programming, so you dont need to take the chip off your system whenever you need to reprogam it).
3. Can be a bit faster (max crystal freq=33 MHz, compared to 24MHz in AT89c5x)
