What are the channel coefficients
g.hadzhiyanev
Newbie level 5
Newbie level 5
Hi, everyone
Does anyone have Idea what do channel coefficients (by channel estimation) mean?
As far as I understand when we have h=[1 0 0 0 0] , we have no ISI. When we have ISI for example h=[0.7 0.8 0.4 -0.5 0.03].
But what is the exact meaning of the numbers?
Thanks
They are the discrete-time impulse response of the channel.
Ideally, one transmitted symbol gives an output only in one symbol time without interfering other symbols, i.e. the response is ...0 0 0 1 0 0 0 ...
In you example, the symbol spreads over several time slices at the receiver with amplitudes 0.7, 0.8, ....
regards
Z
So the position of the number in the vector shows in which timeslot a symbol spreads, and the number with how much of amplitude. Did I get it right? And furthermore does that mean that the channel estimation should always be done before demodulation? Otherwise the results for the channel impulse responses would be complex or I am wrong?
Yes.
No. It is like you mention in the following.
Right. Channel estimation, as well as equalization can be done after demodulation, i.e. in baseband. Baseband equivalent channel is complex.
Regards
Z
