CatKing said:calibre also can be easily integrated in to cadence environment, just update you .cdsinit according the manual. then you can get a pull-down menu of calibre in virtuoso layout editor, you can even perform online drc error check with virtuoso layout editor.
How about Assura? I just used cadence tools diva, dracula and assura. Diva is very slow for full-chip extraction. I do not have parasitic extraction file for dracula. I just use dracula for final LVS and DRC. Assura is much faster than the others. It can extract parasitic inductance and reduce parasitic RC network, although it is a beta feature under testing. It also has 3D extraction engine. Our license can only support RC-extraction. I have no experience with the advanced features of Assura.andy2000a said:Unix
xcalibre > StarRC_xt > Cadence LPE /diva ..
PC
ledit ??
I recently encountered a problem related to MIM-Capacitor extraction with cadence LPE tool. My tool is Assura3.1. The pre- and post-layout simulation have a large difference. I found that it is attributed to MIM-Capacitors. I modified my design according to the post-layout simulation. The chip is under fabrication. After test, I will get the evaluation of the performance of Assura.goodboy_pl said:As I know calibre is more accurate due to semi-3d extraction technology which also provides high speed results.
but cadence tools like dracula have another plus: they are all integrated in the same environment thus is simple to use and there is no need to switch between several tools!
also i have heared that cadence tools can not handle MIM-Capacitors truely but i have no idea about calibre.
BEST!
