What are the applications of CMOS and BiCMOS devices?
Sadegh.j
Advanced Member level 3
Why CMOS?
Why BiCMOS?
bicmos for speed
CMOS is very low power device
for more concern any book related to the basic electronics devices
why cmos
CMOS for low power. BiCMOS for speed.
why cmos
CMOS low power(no static), low area, BiCMOS is better for using BJT in analog and CMOS in digital
cmos cutoff frequency
FOR CMOS. it concerns about the speed which is about the edge of fall time. CMOS is cheaper and small area for IC chip.
For BiCOMS, it boostes the gain of the Op Amp,which is good for analog design. It all depends on project's requirement and your engineering judgement.
Re: Why CMOS
The main answer is money. CMOS transistors are almost free. And CMOS process in nano meter area is quite matured. So its very cheap to fabricate a pure CMOS chip, whereas BiCMOS cost money. So main focus is every function (either digital or analog) on CMOS. BiCMOS is used where there is extreme need of speed which is impossible to get from pure CMOS.
I hope this will help you see technology from industry point of view which is governed by money.
Re: Why CMOS
To get a more general overview, look up CMOS in Wikipedia.com, it's pretty helpful.
Re: Why CMOS
CMOS is for high density, low-cost,
BiCMOS for performance and all advantage of CMOS with more cost
as more mask needed.
Re: Why CMOS
What're the difference between BiCMOS and SIGE? Are they identical?
Mesfet+
Re: Why CMOS
CMOS -- low power, low cost, less area, speed slower than BJT
BJT --- high power, high cost, more area, but faster speed than CMOS
so, when we need high speed with low power, and low cost. Then we go for BICMOS = cobination of both CMOS and BJT
Why CMOS
I think the need for single chip SOC is also a reason. integrate digital and analog into a single chip is very easy for CMOS.
Re: Why CMOS
CMOS is matured for a lot of high volume consumer applications. However, for specific cases (high speed com, very precise structures/references etc) you will need BiCMOS (SiGe, GaAs, and Si)
Re: Why CMOS
Hi.CMOS is low power but cut-off frequency is low
but bipolar has high cut-off frequency about 45GHz and it is usefull for microwave applications
Why CMOS
I wish we got to CMOS devices in my electronic classes :(
Re: Why CMOS
I beg to differ. For bipolar they already have transistors with cut-off frequency over 150GHz. However this is SiGe
