sam khan,
Polyphase motors are inherently self-starting.
In the case of 3-phase motors, the direction of rotation can be changed by reversing the connections to eny two phases.
For a balanced load Wye connection, the neutral current is zero.
For a balnced load Delta connection, the circulating current is zero.
For simple rectifier type DC power supplies the ripple is low, even with no filtering.
Regards,
Kral
