What application uses Rail-to-Rail Op Amp?
dra66ard
Newbie level 5
Newbie level 5
What application that use Rail-to-Rail Op Amp ?
h guys, what application that use rail-to-rail op amp ?
thank you =)
Re: What application that use Rail-to-Rail Op Amp ?
Um, an application where you need the input and/or output to go to the rail...
This question reminds me of a saying by the late Jim Williams, of Linear Technologies fame, which had a quick mind and somewhat sarcastic humor:
Jim: "On a given circuit, there are only three parameters that matter in an op-amp."
Public: "And which are those parameters?"
Jim: "It depends on your application."
Behind what on the surface appears to be a Homer Simpson-stupid response, it actually holds a key truth: the actual way that an opamp is expected to operate in a circuit, will determine exactly which opamp parameters one must be concerned with.
For the OP's benefit, the R-2-R opamps are mostly used where only a single low voltage supply (i.e. +5v or even lower) is available.
An application that comes to mind is high side current sensing, where the inputs have to go to the rail.
Or an application where you're driving an NPN or PNP that may need to be completely shut off.
Or current sensing as mentioned where's shunt is on the rail.
