What amount of baud rate error may be acceptable for long time-period on RS232 port?
buenos
Advanced Member level 3
Florida, USA
Hi
What amount of baud rate error may be acceptable for a long time-period on an RS232 serial port?
In an earlier project, I have used 1% but it has worked rearly. the connection was faulty. after that, I had to replace the microcontroller's (PIC16F877) crystal to a "baud-rate-quarz". then it has worked fine.
Now, I cannot replace the quarz crystal. and I can set the baud rate with a 0.48% error for the required speed. this connection have to be between a TMS320F2811 DSP and a Bluetooth module. Debug is not easy.
Is it depends on the device type?
Re: UART baud rate
"Long time" is not really relevant as RS232 is an asynchronous interface - the
reception is synchronised to the start bit.
I know that some MCUs can handle a 3% deviation so you shouldn't have
a problem really.
UART baud rate
thanx.
i mean on long time: zero error during an hour.
Added after 28 seconds:
receiving all characters correctly during a time
Re: UART baud rate
HI, You can calculate this easy. There are 10 bits in a ASYNC transmission. 8 data bits one stop and one start. The receiver (UART) is re-syncing everytime on the start of a START BIT. so if you want the stop bit to be correctly sampled in the middle of the bit you can see that the maximum error can be: 1/2 BIT in 10 BITS. is 5%. Bo be same stay below 4% + or -
regards,
Paul.
Re: UART baud rate
Slight variation can be done in the crystel frequency by changing the value of the capacitor of CLKIN pin 12pf-33pf.
UART baud rate
In UART usualy we have 10 bits, 1 start bit 8 data bits and 1 stop bit.
First sampling point from high to low transition of stream is in the Tb/2 (half of baud rate period), and second bit sampling point is 3/2 Tb, ...
suppose 10 bits = 100%
If two system clock rates are different, maximum deviation is half of Tb or 5% (last sampling point).
5% value is marginal, and actually maximum value 2%-3% is tolerable.
but if both side clocks isnt precise, maximum 1%-1.5% can be accepted.
Regards,
Davood.
