There is an interdependence between the two layers i.e the driver and the protocol layer of a network driver. VxWorks implements a layer in between the IP and datalink, thus eliminating the interdependence between the two layers. The intermediate layer is known as the MUX layer.
In an ordinary TCP /IP the IP layer is linked to the datalink layer. To implement a new protocol at the IP Layer level, the corresponding driver has to be written or to write a new driver the corresponding protocol has to be taken into account.
MUX is a set of library routines, which decouples the IP layer and the datalink layer. This provides the flexibility and ease in implementing a new network protocol or a network device driver. For implementing a protocol one need not bother about the driver or vice versa. Even a third party protocol can communicate with the MUX.
When an applications wishes to send a packet to the network, the IP layer puts that packet on to the MUX layer rather than sending it to the driver. Similarly when a packet is received, the END puts it on to the MUX.MUX communicates with the IP layer with functions for various services.
Mux layer means L4 of the OSI Model "Transport Layer" which one its main operations is Multiplexing port numbers for Applications , as each application has unique port number , so there're souce port number and destination port number , this function of Multiplexing exist regardless u use TCP or UDP .
