WG2002 class not registered error.
Jayson
Full Member level 4
Full Member level 4
Brazil
mentor system class not registered
When I start the tutorial in Design Capture folder, it says some stuff that it's preparing files for the tutorial after this I do into the Design Capture program and loacte the project the tutorial says to locate, fine I locate it and when it tries to load I get an error that says \..\top.sbk Class not Registered.
After I click ok, I can view the schematic.
Second example with same error: If I go through the tutorial from Library Process (which basically you create a part, it's footprint etc) and place it into a new schematic, when I go to Compile CDB, again the same error and it cannot compile.
What does this error mean and how do I fix it?
-Jayson
mentor design capture error class not registered
Hi Jayson,
I got the same error, it's because VBDCStructSrvr40.dll wasn't registered during the installation process. Try to register it manually.
Example:
regsvr32 c:\Mentor\Shared\VBDCStructSrvr40.dll
Regards,
Elnenez
vbdcstructsrvr40.dll
It worked thanks.
How did you find out that this is what you do? How do I know if something else doesn't need to be manually done aswell?
- Jayson
design capture class not registered
I found out that the problem was it because a warning message during the installation process. I think there're no more problems.
Regards,
Elnenez
emis mentor class not registered
I heard that there is a service pack available, do you know what improvement is makes?
- Jayson
class not registered 00000010
Sorry, but I don't know the improvements it makes.
A question, Which library do you use? the one with mentor pack is very poor.
I'm not using any library. I make my own symbols and PCB footprints, thats the only way I know of working with it. Whats included is a limited considering the price of the program suite.
The problem is the XP SP1 Service pack
On the supportnet of Mentor,
He said : 'The problem is the XP SP1 Service pack'.
best regards
