psyhunter2001
Weird Amplifier Problem
I don't know if anyone has run into this type of issue before but I have designed a simple amplifier using the THS3001. The problem I am running into is that when I have the input signal OFF, the amplifier is still amplifying a 5MHz signal. I have tracked down this signal to be coming from the power pins of the op-amp. Originally I figured that the power supply was broken but it looks like that is not the case. I currently have a 0.1uF cap connected to each power pin. Should I add another cap like around 6.8uF. Or is the problem somewhere else. If anyone has run into this type of problem please let me know. This thing has been driving me nuts to fix.
Thanks.
Thanks.
