Hello Pcbman
The pads version which i am using is Pads2007.
I had problem last time that by mistake i clicked the Increasing Layer mode button and I was not able to go back because when the degin went for verification it was rasised as issue. This board was 14 layer board.
Max Layers
Opens the Increase Maximum Layer Number dialog box.
Tip: When you change to increased layer mode, layer numbers for all nonelectric layers increase by 100.
!PADS-POWERPCB-V2007.0-MILS! DESIGN DATABASE ASCII FILE 1.0
*PCB* GENERAL PARAMETERS OF THE PCB DESIGN
UNITS 0 2=Inches 1=Metric 0=Mils
USERGRID 25 25 Space between USER grid points
MAXIMUMLAYER 4 Maximum routing layer
WORKLEVEL 1 Level items will be created on
DISPLAYLEVEL 1 toggle for displaying working level last
LAYERPAIR 1 4 Layer pair used to route connection
VIAMODE T Type of via to use when routing between layers
LINEWIDTH 12 Width items will be created with
TEXTSIZE 100 10 Height and LineWidth text will be created with
JOBTIME 3 Amount of time spent on this PCB design
DOTGRID 100 100 Space between graphic dots
SCALE 6.989 Scale of window expansion
ORIGIN 23700 23800 User defined origin location
WINDOWCENTER 26511.76 25475.57 Point defining the center of the window
BACKUPTIME 5 Number of minutes between database backups
REAL WIDTH 1 Widths greater then this are displayed real size
ALLSIGONOFF 1 All signal nets displayed on/off
REFNAMESIZE 100 10 Height and LineWidth used by part ref. names
HIGHLIGHT 1 Highlight nets flag
JOBNAME pwrdemoa.pcb
and now the file modified :
MAXIMUMLAYER 2 Maximum routing layer
LAYERPAIR 1 2 Layer pair used to route connection
Import this file in Pads Layout. Go to [Setup] and [Layer Definition] and the pcb has only 2 layers. The 2 CAM Plane are deleted.
I am new in PADS and to learn more I install a PADS demo. My problem now is that I can't view any of the sample projects. Could you help me with this? Thanks.
