qqpost
Member level 1
I have a question about the renormalization. I'm now trying to compare the results of CPW model from ADS to HFSS. When I use the renormalization of the waveport to 50 ohm, the S11 and S21 are much similar to that in ADS (a little difference between them, but I guess they are much close),but the re(Z0(P1)) is always 50 ohm. When I don't use the normalization function, the re(Z0(P1)) is the same as it in ADS according to different structure while S11 and S21 are different.
So, I am just wondering what is the purpose of renormalization? and what is re(Z0(P1)) represent? Just as my guess, the 50 ohm waveport in HFSS seems like the 50 ohm term in ADS. And re(Z0(P1)) is more or less like the characteristic impedance of the transmission line I can get in ADS. Is that right?
Why should we renormalize the waveport? And what does the S11 S21 stand for when non- renormalization for both waveports at the CPW? Is there any meaning for S11 S21 when only renormalize one of the waveports?
Thank you
Thank you
