WAveguide to Coax in HFSS
MobiNaz
Full Member level 3
Full Member level 3
SYDNEY
Hello all,
I am trying to design a wave guide to coax adapter. Should I use two port one for the waveguide end and the other at the coax and look at S21?
What parameter is critical in determining the accurate performance of the device?
Thanks in advance
Yes MobiNaz.
You would need two ports.simple because of the reason you would like to know the transmission coefficients from the transition. and also you would like to measure the bandwidth over which the transition works efficiently.
Regards
Given that the transition is almost lossless, you can also optimize for S11.
