T
treez
Hello,
We have been tasked with lighting up another huge system of outdoor architectural water fountains with coloured LED lamps.
In previous jobs, we find it’s a massive problem with moisture getting into all the connectors and contacts.
Therefore, for this build, we are going to use our new contact-less LED lighting system. For this, there is a single power supply, which puts a high frequency (100khz) sinusoidal current into a 30 metre cable (twisted pair). Its only the power supply we have to keep waterproof. All the downstream LED lamps have no metal contacts, and so they are waterproof. Each LED lamp comprises a ferrite coupler which “clips” over the 30 metre cable wires, and the secondary is embedded in this ferrite as a PCB “printed” secondary. –No contacts! – each lamp can very simply be clipped or unclipped, from anywhere on the cable that we like. It’s a perfect system. Why is no one else doing this?
The current in the 30 metre cable is a beautiful sinusoid due to the resonant topology chosen. The voltage waveform is also smooth.
Can you see any problems with our new setup? What about RF interference? The 30 metre cable wire will be a twisted pair of multi-strand conductors.
Schematic and LTspice simulation as attached.
