bilalinamdar
Newbie level 3
Hello
I want to build a circuit which will alert me when oht is overflowing and when it is empty*
This is the circuit I build using google
Please refer to the image schematic
R1220k
R2 22k
BC557 pnp transistor (empty)
Bc548 npn transistor (overflow)
Relay 6 or 12v
Power supply 9 or 12v
Probe H (overflow sensing) top
Probe E (empty) below middle above probe c
Probe C common for H and E
I don't know much abt electronic but it is my hobby. I m not able to resolve the problem
Problem
The above circuit works gr8 separately but I want to combine both so that they can work together. I know diodes will be needed but kindly explain me where should I use it*
1) i want to drive the relay when the overflow is sensed
2)I want to drive the relay when empty is detected
3) Also I need a indicator for empty and overflow (led red and green)
4) reset button to shut the see below relay desc
What relay will do?
Relay will drive AC door bell. I want something like a bell button or reset button which when pressed and released will disconnect the sound of bell. But will still be armed for next condition match is it possible? *Just like alarm clock when reset is pressed the bell turn off but will sound again after the next alarm hour is met.
Schematic image
Tank display
R1220k
R2 22k
Relay 6 or 12v
Problem
What relay will do?
Schematic image
Tank display
