Water Inlet Valve - Ice Maker
TymerTopCat
Newbie
Newbie level 2
Problem: I have a Whirlpool ice maker that works, but only produces half of the ice during an ice cycle. This problem is because the ice maker is connected to a Rerverse Osmosis (RO System) it has low water pressure. The ice maker does have a water level adjustment, however the adjustment is not enough to fill the ice tray.
Problem: Ice maker turns on the water inlet valve for 7 seconds, I need the water inlet valve to produce water for about 12 seconds instead of 7.
Possible Solution?
Build an analog circuit that uses the 7 seconds of 110 volt output from the ice maker, and creates a (delay off) timer of 12 seconds.
Would this be possible?
Said in other words, the ice maker energizes the water inlet valve (110 volts) for 7 seconds, I need to keep the Water inlet valve open (energized) for 12-15 seconds. Could we use the seven seconds of (110 volts) to charge a capacitor, and then use the capacitor to energize the water inlet valve for 12-15 seconds? The timing of the circuit does not matter as the ice tray fill is the last step in the ice making cycle.
Doubt it. A capacitor charges up to ~63% in one time constant but discharges down to ~37% in one time constant...
Why not look into 'off-delay' relays or modules instead?
Thanks for your reply. I am a software engineer, but not a Electrical engineer. And so I was ignorant of "Off-delay" relays.
I am currently looking into the relays.
I was just looking to solve a simple problem with the simplest solution.
The Off delay relay looks to be one way to solve my problem.
If I am thinking correctly the Off Delay relay can be set to delay off in any number of seconds:
Not sure how to wire this Off Delay relay into the system. Because I don't know (yet), the behavior of the Off Delay Relay.
If I wire the Off Delay relay to the ice makers 110/120 volt output in front of the Water Inlet valve, When the Ice Maker energizes the Off Delay relay for 7 seconds and then turns off. Will the Off Delay relay continue to energize the Water inlet valve for 5 more seconds, after the the power is cut?
I may have to have an additional power wire to power the Off Delay relay?
...and I don't know anything about the innards of icemakers, unfortunately.
Pictures of wiring and documents or links to device specifications are a more accurate way of people offering informed suggestions.
You can get on or off delay switches that turn on or off at the start or end of a signal, all flavours for all needs, and additional power path would be needed for one.
If you can put together a picture of the icemaker wiring, a smarter person than myself will be able to suggest what goes where, hopefully.
Here's a method to extend a DC pulse (although it's not clear if the initial signal is AC or DC):
To obtain longer discharge time from the capacitor, we can make the transistors a Darlington pair, which draws very little bias current from the capacitor. Thus its value can be small and less expensive. With a little effort you can change it to an NPN-PNP pair, relay, scr, etc.
This is theoretical of course. The above is similar to a sample-n-hold circuit. It's not likely you can simply drop it into your ice maker. You need to find out whether its voltage is AC or DC, and how the 7 seconds of On-time is obtained.
And your whole job is easier if you can find a built-in adjustment for On-time in the ice maker.
First please download an OFF_delay_relay datasheet. There should be wiring examples (if not choose another datasheet).
Read to them.
If then still something is unclear, then please post a (hand drawn) sketch of the current wiring.
Klaus
