Wat does it mean by 12,8 mm distance optoisolators?
ericmar
Full Member level 5
Full Member level 5
Singapore
hi all,
I'm quite new to optoisolators so i hv no idea wat this phrase means. Can u guys explain to me?
The whole original line is "FIMET’s new iOX sensor has 12,8 mm distance optoisolators in the signal line of the USB and 4 kV/12,8 mm galvanic isolation in the power lines."
Wat abt the "4 kV/12,8 mm galvanic isolation"? Wat is this?
Thx a lot!
Wat does it mean by "a 12,8 mm distance optoisolators&a
That means the transmit and receive circuits are physically separated by at least 12.8 millimeters, and can withstand a voltage difference of 4000 volts. That probably complies with an isolation safety requirement.
    ericmar
Re: Wat does it mean by "a 12,8 mm distance optoisolato
Is that actually a typo since it said 12,8 mm not 12.8 mm?
Thx anyway! :D
No, it is not a typo. In many countries, the comma is used instead of the period for the decimal point.
