no_spark
I have a combo washing/drying machine. It uses cold water to remove moisture in the air while drying. A universal complaint on these is the loud drone of the water pump every 30 seconds or so.
If possible I would like to quiet the pump. Using variacs I have been able to slow down my household fans from the 1920's. Would this method work/be ideal on a water pump?
The machine will throw an OE (tub not drained) error if more than 10 minutes are required to empty the tub. Right now the pump can drain the full tub in only a minute, so I think there could be room to slow things down. There is room in the washer cabinet for a panel mount variable transformer, if this worked I could adjust the speed once in for enough power while still being quiet.
I found a variac for sale on ebay. I am not quite sure what specs I would need. The washing motor is running on 240v AC from the main PWB?
Wiring Diagram:
Pump Motor:
Pump:
Variac:
Power input:
I have installed this washer where the oven once was. The wall outlet located close is a 240V circuit. The washer runs on regular 120V power. When the heater is on the washer draws 2000 watts so I am close to the limit of my 120v circuit. Can I add a drop down transformer to power this that would simply plug into the wall outlet > convert to 120 > and have an outlet to add this washer to?
From what I have read I am on a NEMA 10 -50 which is obsolete and possibly dangerous? Also, I would need to change a breaker to 15a? I am looking for a safe plug-in only solution without modifications as I do not own my apartment.
Oven plug:
Step down transformer:
Wiring Diagram:
Pump Motor:
Pump:
Variac:
Power input:
Oven plug:
