Warning XST: 2677 - Node of sequential type is unconnected in block
State
When I am synthesizing my code with Xilinx ISE 9.2 I am getting the following warning about 2000 time.
Xst:2677 - Node <my_signal> of sequential type is unconnected in block <block>.
I am a little worried since I really don't know what exactly what could be the source of the problem. So if anybody could give any tips it would be greatly appreciated.
State
warning:xst:2677
That warning is caused by lot of things.....
One main reason is if your outputs are not connected..ie if you are not reading the module outputs the ise optimisation step removes all signal inside your block and fire a 2677 warning...
check the module outputs
S
Thank you got it perfectly right. I had actually forgot to link my register to the output..
Sate
