Warning when launching c@dwnce !c5 under mandrake 9.1
lcg22
Member level 5
Member level 5
x toolkit warning translation table syntax error
When I install !C5.0 for the first time, I did not have this problem. However, my system was coorupt and I re-installed it. I get warning now.
[user@localhost user]$ icfb
Warning: locale not supported by Xlib, locale set to C
problem with xkeysymdb redhat
try this:
unsetenv LANG
then start icfb again.
w x toolkit warning icfb
setenv LD_LIBRARY = $LD_LIBRARY, $path/Xlib
retry
icfb w x toolkit warning
Since these new OSs use newer library (glib, libc,...), IC5.0 seem incompatiable with redhat 9.0 and MDK 9.1.
You can try to install under Redhat 7.3 or 7.2.
Redhat 7.2 is testing platform of most linux version eda tools.
I understand RH7.2 is the best platform for most EDA tools, however I have lost the disks and cannot find it now. Do you know where can I download it now?
Amuro said:
http://www.linuxiso.org/distro.php?distro=7 for Redhat and you can find other popular distributions also.
It's not a complete ISO file. Only 242kB. Thanks anyway.
Thank you, I have tried 7.3. It's even worst than mandrake 9.1. The system is very slow. :(
\w X Toolkit Warning: translation table syntax error: Unknown keysym name: osfMenuBar
It should be an xkeysymdb problem. Check your X11 settings.
#cshrc example
setenv cds_root /usr/cadence/ic50
setenv XKEYSYMDB $cds_root/share/cdssetup/tdmX11/XKeysymDB
Have fun!
SeanC
#cshrc example
Have fun!
SeanC
Thank you. You are right. Actually, my problem is this:
this seems to be my linux system problem, I don't know how to solve it.
Same thing, add the following settings... :wink:
setenv XNLSPATH $cds_root/share/cdssetup/tdmX11/nls
SeanC
lcg22 said:
#cshrc example
Have fun!
SeanC
You can refer to sourcelink, the solution number is 11078930. I found it today.
Have fun.
How to log in to sourcelink? Can you post the solution here? Thanks
You need account from Cadence to log in. The solution is descripted above.
SeanC
