Warning when doing place&route in ISE
phoenixfeng
Full Member level 2
Full Member level 2
help:ISE place&route
when place&route ,the warning below happen:
WARNING:SpeedCalc:42 - Cannot find referenced model "bel_d_min_period". This
generally indicates that there is an inconsistency between versions of the
speed and device data files. Please check to ensure that the XILINX
environment variable is set correctly, if the MYXILINX variable is set, make
sure that it is pointing to patch files that are compatable with the version
of software that the XILINX variable points to.
how should i do?
Re: help:ISE place&route
let try to delete ur user constraint file and add a new user constraint file with differnet name... mostly u use different fpga family from the ucf in ur project
Also check if you have the latest device files from xilinx. A new UCF will also help.
BRMadhukar
Remove time setup constraints.
