Warning message during simulation in ADS
Mabrok
Full Member level 4
Full Member level 4
I am doing power amplifier design and got this warning message during the simulation. However, the simulation result is ok. But, I am worry about the measurement results after fabrication. As message mention about the dimension limitations of microstrip. Thank you Untitled112.png
Physical Transmission Lines have some valid models for simulations and this validity has some limits as expressed ADS Warning messages..
Correct the TL parameters otherwise even the simulator terminates the simulation, the results will be erroneous due to those constraints.
Thank you for your response. The simulator did not terminate the simulation, and shows good results. Just I am worry that this could affect measurement result.
