want to use Proteus make blocks missed parts why?
laoadam
Member level 2
Member level 2
I want to make the small parts of circuit into blocks, but not work, say three buttons make as one block, the result is missed other two.
Not clear what you did, but the 'subcircuit-mode' feature is likely what you need:
Thank you.
Some times when I wiring device pin, it shown a red circle and refused, why?
Thanks.
Watched the video, can you tell hot to modify attached drawing's mcp4261 section into sub-circuit?
