alpha91
Full Member level 3
Hi all, i am new to microcontroller, i wish to learn to programming and i know very less about it. Can i know any website that is for beginner? and i not sure whether assembly language or c language is better.
This is good tutorials for beginners
Ardiuno is a good place to start the main factor there is lots of information and projects out there
, I found by reading lists of books and reading through others people code gives an excellent ideas how to understand and write your own code
Go for PIC programming. You can configure registers to create Timer delays, generate PWM signals, etc... You will learn more.
I think you should decide what kind of controllers you want to start working. Of course this choice is not final, in the long term you can easily switch to almost any other.
I would advise to first select the type of controller in which a lot of information and examples. Alternatively ATMEGA or STM32. These controllers are VERY much information - try GOOGLE.
STM i think is quite expensive right?
