rajnish_rohit
Newbie level 3
Want to know how to integrate HMI with micro controller
Human machine interface/man machine interfaceWhat is HMI?
As you don't specify your HMI more detailed: just use a LED and a pushbutton.
Klaus
"Integrate HMI with microcontroller" means you are setting up a MODBUS server the HMI should talk to? But what's exactly the problem? Do you understand the protocol used by the HMI? How do you configure it? Are you sure your MODBUS implementation is correct? Did you check it with a test tool?I tried with modbus ASCII but the HMI keeps on sending the strings and after send the return reply to specific string after few milliseconds hmi again send the string
