want the equivalent verilog code for this
raghava216
Junior Member level 3
X : for i in 1 to 7 generate
process(clk,rst)
begin
if (rst = '0')then
d1(i) <= '1';
d2(i) <= '1';
d3(i) <= '1';
d4(i) <= '1';
elsif clk'event and clk = '1' then
d1(i) <= int_n(i);
d2(i) <= d1(i);
d3(i) <= d2(i);
d4(i) <= d3(i);
end if;
end process;
pend_set(i) <= d4(i) and (not d3(i)) and (not d2(i));
process(clk,rst)
begin
if (rst = '0')then
pend_n(i) <= '1';
elsif clk'event and clk= '1' then
if (pend_set(i) = '1') then
pend_n(i) <= '0';
elsif ((i = conv_integer(ack(2 downto 0))) and ack(3) = '0' and ack_n='1'
and ack_n_d3 ='0') then
pend_n(i) <= '1';
end if;
end if;
end process;
end generate X;
I am trying to convert this VHDL code to verilog.
I started with the generate statement then the problem is I can't write an always block inside a for loop in verilog.
Please suggest me how to write the above code in verilog correctly.
module try(input rst, clk, input [7:0] int_n);
reg [7:0] d1, d2, d3, d4, pend_n;
wire [7:0] pend_set;
always @(negedge rst or posedge clk)
begin
if (!rst)
begin
d1 <= 8'b11111111;
d2 <= 8'b11111111;
d3 <= 8'b11111111;
d4 <= 8'b11111111;
end
else
begin
d1 <= int_n;
d2 <= d1;
d3 <= d2;
d3 <= d3;
end
end
genvar i;
generate for (i=0; i<8; i=i+1)
begin: g_generate
assign pend_set = d4 & (~d3) & (~d2);
begin
if (!rst)
pend_n <= 1'b1;
else
begin
if (pend_set)
pend_n <= 1'b0;
end
end
end
endgenerate
endmodule
seem to compile with modelsim,
I did not complete wrotte your second process.
Try this code:
genvar i;
generate for (i=0;i<8;i++)
begin : generate
always@(posedge clk or negedge rst)
begin
  if(!rst)
  begin
    d1[i] = 1'b1;
    d2[i] = 1'b1;
    d3[i] = 1'b1;
    d4[i] = 1'b1;
  end
  else
  begin
    d1[i] = int_n[i];
    d2[i] = d1[i];
    d3[i] = d2[i];
    d4[i] = d3[i];
  end
end //always
assign pend_set[i] = d4[i] & (~d3[i]) & (~d2[i]);
always@(posedege clk or negedge rst)
begin
  if(!rst)
     pend_n[i] <= 1'b1;
  else
  begin
    if(pend_set[i] == 1'b1)
       pend_n[i] <= 1'b0;
    else if ((i == (ack[2:0])) & (~ack[3]) & (ack_n) & (~ack_n_d3))
       pend_n[i] <= 1'b1;
  end //if pend_set =1
  end //rst & clk
end //always
endgenerate
@rca its showing some errors in your code... however i thank u for giving an idea how to proceed
@vlsi_whiz What you pasted here is almost working. After a few corrections, I got no errors now. Thank you.
