Want a protect circuit
shalky
Newbie level 6
Newbie level 6
A serial LC resonance circuit need to be protected from big current , so I want to use a current check circuit and decide if the power switch cut off. A few seconds delay time is needed.
Any suggestions and ideas will be helpful.
Regards
please be more spesific.
Do you mean you need a delayed starter?
You could use a 555 timer and connect it's output to a transistor to power your LC circuit.
hmmm what about slow blow fuse? that works too. You need to be more specific as to what your needs are
Finally, I use a MCU to process the power switch and make a soft-start circuit to protect. Thanks to everyone helped me !
