Wallys// support 2x WiFi 6E Card support BT5.1 industrial wifi6 router ipq5018 QCN9074/QCN9024 M.2
Founded in 2010, Wallys is mainly engaged in the research and development and production of wireless communication products, providing OEM/ODM/JDM services for customers.
Equipment and capacity: The company has 4 SMT production lines, 2 wave welders and
manual welding lines, and 2 test assembly lines, with an annual production capacity of
10 million PCS.
Welcome to email us for any project or question about RF and embedded systems
Moreover, we can also do FCC and CE certification related to wireless communication products for you. There is a better price for certification in China.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
Today I will introduce the industrial wifi6 router/moudle.
DR5018 is a router based on Qualcomm IPQ5018 chip.
It has two M.2 card slots
A wifi 6e card
One supports M.2card slot for 5G, quectel.
Support BT5.1
It has four 1g Ethernet ports
2x2 2.4 wifi antenna interface.
If you need to customize related hardware parts, wallys can also help you realize your customized functions, such as gps, lte and so on.
Let's take a look at the M.2 card that it supports.
Wallys currently offers three M.2 cards, all of which are based on Qualcomm QCN9074/QCN9024 chips.
These three cards, and all are 4x4, but respectively have three frequency bands of 2.4G/5G/6G, the difference between this card.
Let's just look at one of them in detail.
DR9074-6e, 4x46 g M.2 industrial moudle.
PCI Express 3.0 Interface
Antenna Cable/Port: 4 x MMCX Connectors,4T4R. Antenna Cable/Port: 4 x MMCX Connectors,4T4R.
Frequency Range: 5.925 GHz to 7.125 GHz
Another card supported by DR5018 is the M.2 card, which is the QUECTEL MODULES.
5G RM500Q-GL
5G, LTE cat 16, USB 3.1
GNSS (optional) VoLTE(optional)
5G sub-6GHz module
52.0mm x 30.0mm x 2.3mm
8.4 g
M.2 form factor
Max. downlink 2.5Gbps / 900Mbps uplink
Extended temperature range of -40°C to +85°C
Of course, whether these cards are needed depends on the customer's own project requirements and parameter requirements
If customers need antenna, shell and other requirements, wallys can provide them.
Wallys Communications (Suzhou ) Co., LTD http://www.wallystech.com
