VXL PICK FROM SCHEMATIC'S SIZE PRAMATER PROBLEM
GPSGPS
Newbie level 2
Newbie level 2
HI,
I just installed cadence 5.141 with VXL, everything works good, but one thing, when I open a schematic , then VXL, then CREATE-->PICK FROM SCHEMATIC, I got problem, I can only get a correct sized PMOS, NMOS, but not other symbols, like inverter, nor2....when I pick them over to VXL window, they just turn to be many standard PCELLs with minimum size.
so I tried to setup CDF, I can use pick from schematic for other symbols, but they are just the instances (not PCELL,and the instance's size is not linked to the parameters what I set in schematic) of what I built, I beleive I did some setting wrong on CDF,
what should I do to setup a correct PCELL size parameter link schematic to VXL? or, what should I read? thanks.
