fouwad
Full Member level 4
Hi all
i am using VS 2012 and SQL Server 2008
a chunk of code is to be called repeatedly
i have placed it in a timer tick event
it is taking longer than anticipated and as the time passess the execution time increases
i am posting the potential area of problem
thanks
thanks
if (ds_alarms.Tables[0].Rows.Count != 0) //resolving four different types of alarms for all signals in ds_alarms
DateTime time = DateTime.Now; // Use current time
SqlCommand sql_Al=new SqlCommand();
sql_Al.Connection = connection1;
var alarmSet = ds_alarms.Tables[0].Rows;
for (int i = 0; i < alarmSet.Count; i++)
int index = listOfTags.FindIndex(x => x.Equals(ds_alarms.Tables[0].Rows[i].ItemArray[0].ToString().Trim()));
bool isAlarm = bool.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[5].ToString()) == true;
bool isAlarmValue=engValues[index] > float.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[1].ToString());
if (isAlarm && isAlarmValue)
sql_Al.CommandText = "INSERT INTO [MCRCDA].[dbo].[Alarms]([DateTime],[TagName],[AlarmType],[Value],[Units],[Address]) VALUES(" + time.ToString(format) + ", '" + ds_alarms.Tables[0].Rows[i].ItemArray[0].ToString().Trim() + "','HiHi'," + engValues[index] + ",'" + ds_alarms.Tables[0].Rows[i].ItemArray[9].ToString().Trim() + "','" + ds_alarms.Tables[0].Rows[i].ItemArray[10].ToString().Trim() + "')";
try
if (connection1.State != ConnectionState.Open)
connection1.Open();
sql_Al.ExecuteNonQuery();
connection1.Close();
catch (Exception exp)
MessageBox.Show(exp.Message);
isAlarm = bool.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[6].ToString()) == true;
isAlarmValue = engValues[index] > float.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[2].ToString());
try
connection1.Open();
isAlarm = bool.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[7].ToString()) == true;
isAlarmValue = engValues[index] < float.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[3].ToString());
try
connection1.Open();
isAlarm = bool.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[8].ToString()) == true;
isAlarmValue = engValues[index] < float.Parse(ds_alarms.Tables[0].Rows[i].ItemArray[4].ToString());
sql_Al.CommandText = "INSERT INTO [MCRCDA].[dbo].[Alarms]([DateTime],[TagName],[AlarmType],[Value],[Units],[Address]) VALUES(" + time.ToString(format) + ", '" + ds_alarms.Tables[0].Rows[i].ItemArray[0].ToString().Trim() + "','LoLo'," + engValues[index] + ",'" + ds_alarms.Tables[0].Rows[i].ItemArray[9].ToString().Trim() + "','" + ds_alarms.Tables[0].Rows[i].ItemArray[10].ToString().Trim() + "')";
try
connection1.Open();
