grindylow
Newbie level 6
Voltage Control for Power Supply
Hello people,
I have an of-the-shelf SMPS and I want to use it as a battery charger. I will be using a MOSFET driven by a PWM on a microcontroller to control the current. My problem is how to control the voltage while preserving the maximum current of the power supply. The voltage of the power supply is 12V and there would be a parallel load while charging. The voltage(in CV mode) for the battery is 10.8V. The voltage must also be controlled by a microcontroller. I think that resistor divider is not an option here. What device could I use for this application?
Thanks,
Homer
Hello people,
Thanks,
Homer
