voltmeter with 7107
nohutpilav
Newbie
Newbie level 3
Hello everyone,
I'm new to this site. I'm sorry if I'm wrong. I'm designing a voltmeter with the 7107 integrated.
I implemented a circuit I found on the internet in Proteus simulation and it worked.
However, I can only measure in the 0-200V value range.
Although I applied the resistance change written on the site, my voltage capacity does not reach 2kV.
Please help.
Is your 2KV DC only or does it have a lot of noise ?
How do you confirm you are feeding exactly 2KV to the resistor divider input path
for the 7107 ?
Your 2KV divider, what are the resistor tolerances ? Are they clean, no residues on
them ?
Regards, Dana
for the 7107 ?
them ?
Regards, Dana
Hey dana. I mean I can only see voltage up to 200V on the screen. I can't even see 201V on the screen or 300V or 400V
No, this should not be my solution. When the input voltage is above 200v, I cannot see a value on the screen.
I guess you have a reason to say so.
But I would be very surprised if the display shows more than 199.9 as long as the D1.1 switch is closed.
but
* we don´t know which site you refer to
* nor do we see where and how you "applied the resistance change".
Klaus
