d123
Advanced Member level 5
Hi.
Having a trouble-shooting problem with a home-made voltmeter which reads the output voltage of a power supply.
The power supply transformer has two secondary windings, so there are two DC supplies that cover +5/6/7/9/12/15V outputs.
Both supplies, and the soldered voltmeters and ammeters worked fine when I was bread-boarding and testing the last stage which was the specific resistor values to get the output voltages approximately right. Since adding the resistors and rotary switches, one of the voltmeters can measure 12 and 15V fine, but now says "1" (over-range) for 5/6/7/9V outputs - it didn't do that a few days ago, it functioned correctly.
I checked the banana plugs with a DMM, and the output voltages are correct, it's one of the home-made voltmeters that has the anomalous behaviour.
Not sure why it would matter, it didn't during the testing stage I mentioned: supply/voltmeter/ammeter #1 run off the same line as the fan, supply/voltmeter/ammeter #2 have no fan on their line, and #2 voltmeter works fine.
As far as I can see there are no wiring mistakes (both are the same in every respect, unless I'm missing something).
Has anyone had a similar experience? I could understand the higher voltages causing an over-range if something were wrong, but not those below 9V, doesn't make sense to me.
Attached is a schematic with the power supply, and a schematic of each 'meter.
Before anyone rightfully rubs their hands to point out a lot of things unrelated to the question , it's not a very good power supply, I'm trying to disown it in a crowd, and I wouldn't make one this way again if I had to.
Does anyone have any guesstimate ideas why would one have over-range for lower voltages, but the other be fine, when in principle they are identical, and have been through the same process?
I can upload a photo of the back of the front panel where all the relevant wires mingle, if that would help.
View attachment Power supply - Schematic.pdf
Thanks.
Thanks.
