666shan666
Newbie level 3
I need some assistance regarding step-up transformers.
I used to live in Chandigarh, India & the voltage here varies from 220v-230v. But recently I move to the outskirts of the city & now where I live has a lot of voltage issues. Due to this one of my computer UPS got burnt, literally. I need to power up my 1200 watt computer for which I am using an APC BR1500-IN with extra battery. The problem is that the voltage never stays at 230v. Rather, it rarely reaches 230v. It some times fluctuates between 212-216 volts, but more often than not, stays at 188v-194v. Frequently, goes below 180v to to 164v, 150v & even 130v. The APC power chute software helps me get these values. I was using a stabilizer & a surge protector, they cant fix a voltage this low. Due to this, the UPS does not charge properly. I charges when it receives 204v or above. when the voltage goes below 180v, the UPS switches to battery power. I need to convert this low voltage to 220v or 230v stable to ensure no loss of property. I was looking at a 2000watt step up transformer imported from US- New 2000W Step UP/Down Voltage Converter Transformer $ (Rs. 5863)
What I want to know is, if this transformer requires 110v-127v input, what effect will it have if it gets 188v or more?
If that is fatal to the transformer, can I connect two of them in series? One will connect to 188v input to 110v output, & this output will connect to 110v input of second transformer to 220v output. Will this combination, or for that matter, anything work for me? Or is it just a wild goose chase?
