voltage to frequency converter
Ten Y Dash
Newbie level 6
Newbie level 6
voltage to frequency converter using 555
hey,
I need to create a voltage to frequency converter that will take an input analog voltage between 0 and +5 V and output a frequency.
It seems the easiest circuit to use would be a 555 timer circuit, does anyone know how to design this or know of where I could find a circuit schematic.
my Vcc is +5V
Thanks
555 timer voltage to frequency convert
What frequency / range are you looking for on output ?
555 is simple and crude, assuming a linear input, but if you say used a PIC or AVR with A/D on board, you could program the O/P on an I/O pin and code define the tables yourself and compensate for any adjustments on Vin
:F
