TunerPhish
Junior Member level 3
- Joined
- Jun 21, 2016
- Messages
- 31
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 8
- Activity points
- 229
Why do you talk about "the threshold voltage"? The datasheet does not say anything about a threshold voltage. A Mosfet has a threshold voltage.
Why do you suppose it? Of course it is, in comparators with positive feedback we speak about positive threshold and negative threshold or High Threshold and Low Threshold.The circuit topology is that of a voltage comparator, so I presume the threshold is the voltage at which the output goes from high to low or from low to high.
Yes, of course the meaning of threshold of a comparator is unique.Why do you suppose it?.
But even the old uA741 can perform tasks of a good comparator IC if positive feedback is involved, isn't it?But an opamp was shown, not a comparator IC.
Of course it is the threshold voltages for a comparator that has positive feedback. But an opamp was shown, not a comparator IC.
A school kid would use ohm's law to calculate the threshold voltages.
I think the teacher wants the students to see that a 48 years old opamp makes a poor comparator.
Maybe. First you must calculate the frequency then look on the datasheet for the opamp to see if its frequency response can produce a squarewave at that frequency.The next stage of the problem is to sketch the waveform of Vo. Would this be as simple as sketching a square wave using the values 0v and 3v. Thanks
Triangle voltage crossing of 0 and 3 V thresholds causes the output to switch between minimum and maximum level.Would this be as simple as sketching a square wave using the values 0v and 3v.
