voltage stabilizer design - need help
hanif
Full Member level 4
Full Member level 4
Pakistan
I want to design a voltage stabilizer for home purpose. although they are available in markets but i want to design for learning purpose as well as using good material because local manufactures used sub graded material (for winding etc).
i would be appreciated i some one tell me the basic behind (calculation , equations etc)it as well as provide a sample design circuit, even recommending a good site regarding voltage stabilizer design tutorials is also welcome.
load for voltage stabilizer is 600 W (fans , energy savers).
for simple stabilizer you can use analog circuit using op-amp or transistor ( normal one in market from 170-270v ) . if you want fast switching and more range go for micro controller design
thanks for your reply, what i need is the basic principles and calculations (regarding voltage regulator or stabilizer design for AC mains) as well as a schematic for a simple voltage regulator circuit .
it sounds like a job for powerint.com
