toolsrbob
Newbie level 3
- Joined
- Sep 27, 2010
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Washington State
- Activity points
- 1,310
all,
I am new and not sure if I am asking my question in the right place.
I have several variable ac voltage inputs that range form 1 volt to 30 volts.
I desire to have a steady dc voltage output but to also utilize the extra curent created from the input source over the dc voltage level..
Example: if I have three ac inputs of 5v ea and I want a 10 volt dc output.
how can I add all three ac voltages, regulate to 10 volts dc and utilize the extra curent in the extra 5 volts over the dc level.
and if each ac input goes to 18 volts, how can I series the inputs, regulate them to 10 volts dc and utilize the extra curent in the over voltage.
Is this possible using solid state devices, not waste a lot of power and generate a ton of heat.
thank you for your time
