ghattas.akkad
Member level 1
hello i was thinking of developing a voltage regulator using only a pic
where you can input any voltage in the range of 5 to 24 volts and output either 5 9 or 12 volts
is this possible to implement using only a pic and opamps ? without the use of variable regulators
i was thinking of using the internal pic comparators and upon the result output a "1" at any pic port equivilant to a 5V
and then increase it using the opamps
