d123
Advanced Member level 5
Hi!
The circuit below is not functioning as I'd hoped/expected. This is an experiment making a milli ohmeter, that is the purpose of this circuit; I was unable to breadboard it, or simulate a couple of the ICs, so I just made a prototype to see what would happen, therefore it's very rough and ready.
Are there any obvious mistakes in the design that would cause a predicted 100mA constant current appear to be in fact 2A?
The voltage regulators are supposed to be putting out 5V and 100mA...
- The 73801 which supplies the ICs does output 5.02V, not sure of its current output (yet) as that is not an issue.
- The 73801 which feeds the DUT resistor part of the circuit supplies a poor 1V, and according to the multimeter is blasting out 2.1A down to 1.6A by the time the 555 "Start" pulse ends. Bad for the battery too. I understand this high current is why the output voltage is only 1V, and not 5.02V.
(The 555 "Start button" sends a signal to the 73801 "enable" pin, otherwise the 73801 for the DUT resistor has 0V output).
The formula from the TPS73801 datasheet is also here as a jpg. I understood that 1.21V/12.1Ω = 100mA. As the predicted output voltage for the regulator was 5.04V and one is supplying 5.02V, I imagine I have understood that calculation correctly, but don't understand why the current is so high. I used 12.1Ω for R1 and 38Ω for R2.
Any ideas? Is some component like an additional resistor to limit the current missing from this circuit?
Thanks.
Thanks.
