Voltage of TIP&RING
meisam_elec
Newbie level 1
Newbie level 1
I am going to Measure the voltage of Telephone Line with microcontroller(AtoD).I mean the voltage between the TIP and RING.
I used ATMEGA32 microcontroller.Now it's impossible because the GND of the circuit is different from TIP&RING.
Who can help me by giving a solution??Thanks
One solution would be to isolate your circuit's power supply. Then you could use either TIP or RING as a ground for the circuit.
cyberblak
thanks a lot
__________________
