sizo0708
Hey everyone, I am trying to calculate the PCE (power conversion effeciency) of a 5 stage low power voltage multiplier using the HSMS-2850 Scottky diode and I have some kind of error because the value goes beyond 100% after a certain input power value.
I tried to use 2 different methods to calculate the PCE and they are both problematic (They can be seen in the images).
A transient simulation of input and output voltage is shown at an input power or -20dBm.
Also, voltage multipliers with fewer stages should have a higher value of PCE because there is less power loss in the diodes, but I get the opposite when I simulate voltage multipliers with less stages...
What may be the problem? Is it the sceme or is it the calculation method?
Kindly help.
Kindly help.
