Learner1234
Newbie level 6
Hi guys. I have to design a dual polarity output SMPS. I'm quite puzzled how to implement the input voltage divider section for that.
As an example plz see the attachment. The figure 1 is ok as it is single supply output section and no problem with input voltage divider resistors.
However for dual polarity output power supply section given in figure 2 is not complete and I have simulated in LTspice and it shows that R Upper- (R9) resistor in figure 2 has no impact on the loop, being grounded and only R Upper+ (R7) and R Lower+ (R8) will define the output voltage, hence if load at both outputs are balanced always then no problem and if not balanced then it's in problem. Also there will never be any check on negative supply rail for regulation. I have searched the net and could not found any method which caters this issue if OpAmp is used and particularly if single OpAmp is used with another restriction that it should be single supply OpAmp. In case of TL431 there is easy method to implement dual polarity output but I'm bound to use one single supply OpAmp only, or any corrections needed in figure 2 so that this sections becomes complete in itself. Any idea how to implement it.
