noiprocs
Newbie level 2
averaging circuit
I'm currently designing a circuit that will be used as a signal conditioner for a data-logger. It will be measuring the current consumption of a battery powered device. I plan to use a 4ohm resistor to convert the current into about 100mV (at 25mA) and then amplify with an opamp.
Thats all OK, heres the problem:
The device switches on/off a radio chip that uses 25mA. It uses about 10uA when it's turned off. It turns on for 100us; the sample period of the data-logger is 500us! Obviously the data-logger could completely miss the spike! What I would like to do is build some form of averaging circuit so that the spike will always be captured (maybe in 2 samples) so I am still able to work out the energy consumed by the device.
Does anyone have any ideas or calculations that I should be following?
thanks
thanks
