adigwe
Junior Member level 1
Hi there, I need some help.
I have a sample and hold circuit comprising a TL071 opamp and capacitors. My output turns out to be a pulse whose mark(high) is 9v( Vsupply to opamp is 9V).
How do I convert the pulse to a 5V mark(high pulse). Or better still is it posible to have a response such that when the pulse is running the circuit reads high and when the pulse stops it goes low.
I just want to know if there is a method of detecting a pulse stream that is not too complex and if you can modify it to any voltage level say TTL.
Hoping to hear from you all.
Thanks.
Thanks.
