neazoi
Advanced Member level 6
Hi I need a variable frequency audio oscillator circuit that operates from 480Hz to 2700Hz. I do not care if it is square wave or sinewave (squarewave better).
What I do care is that the frequency can be varied with voltage and the output is around 50% duty cycle (not precisely critical).
I want to avoid any proprietary ICs. Discrete components or common ICs like the 555 are fine.
Can you please suggest me such a circuit?
Thank you
Thank you
