ivan_the_red
Newbie level 1
Good Day All,
I am trying to come up with a simple answer for a problem that I cannot solve.
Heres my situation.
1.) I have a transducer that has the following output characteristics. The unit
has a voltage output of between 0 and 5.62 volts d.c.
2. I have a panel meter that I have to use that will read between 0 and 1 volt d.c.
3.) There may be times when the lower voltage would be 2.2 volts or 3 volts
etc. etc. (the lower voltage will vary with a changing application)
4.) There may be times when the higher voltage would be 4.5 volts or 4 volts
etc. etc. (the higher voltage will vary with a changing application)
5.) I need a circuit or an idea of for circuit that would allow these output voltage
scenarios to always be converted to a low voltage of 0 and a high voltage of
1 so that the same panel meter can be used, Its a total mystery to me and
any help would surely be appreciated !!!
Thanks All
Heres my situation.
Thanks All
