FalloutBoy
Junior Member level 2
Hello,
I have sunk a large sum of money into my hobby project so feel it's better to ask this now.
I am using Eagle PCB 7.10 professional and am re-entering a very large schematic in order to produce a board for a piece of old tech under a modern board design, to give you an idea of the scale of the project I am undertaking the board itself is 13 x 15 inches (330 x 381 mm), is double sided, has 2895 air wires to be routed and contains 3725 pads and 558 components.
The main 5v DC supply runs at 3 amps, this is the largest draw in the whole board.
My concern is that Eagles router although it routes the whole board 100% and optimizes it down quite happily swaps sides of the board a lot as it is routing and I do not know if it is an acceptable / advisable / safe or done practice to let supply lines and grounds do this - yes its only 15 watts we are talking about; however is all this side swapping ok or am I better to drop the auto route and route the whole thing by hand?
What possible problems could occur?
